Disables IP forwarding over calculated MPLS LSPs to subnets learned via OSPF.
| vrf_name | Specifies OSPF on a particular VRF. |
Disabled.
This command disables IP forwarding over calculated MPLS LSPs to subnets learned via OSPF. (Calculated refers to an LSP that only reaches part of the way to the destination). By default, IP forwarding over MPLS LSPs to subnets learned via OSPF is disabled.
In order to disable OSPF on a particular VRF, you must supply the optional vr vr-name CLI parameter.
The following command disables OSPF‘s use of MPLS LSPs to reach OSPF routes:
disable ospf mpls-next-hop
This command was first available in ExtremeXOS 11.6.
The vr keyword and vrf_name variable were added in ExtremeXOS 15.3.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
